By ArnaudC - 4/13/2022 11:52:00 AM
In my corner of Europe, I can barely get a single MET update via 3G above 2500ft. 4G disappears lower than that. If you really want live trafic in the plane, get a SkyEcho.
By rv8ch - 4/22/2022 9:26:37 AM
+xIn my corner of Europe, I can barely get a single MET update via 3G above 2500ft. 4G disappears lower than that. If you really want live trafic in the plane, get a SkyEcho. In flight, the skyecho is fine, even if it "only" shows ADS-B and FLARM. For looking at traffic at a far away place on the ground, it's not too useful.
My use case is from time to time I'd like to see the traffic flows around a destination airport during my flight planning phase, on the ground. True, I can do this another way, but I did get used to this when using FF, and having now switched to SD, I wondered if it was possible to add this feature. If not, not a huge problem. Just asking.
By erchegyia - 4/22/2022 11:09:41 AM
+x+xIn my corner of Europe, I can barely get a single MET update via 3G above 2500ft. 4G disappears lower than that. If you really want live trafic in the plane, get a SkyEcho. In flight, the skyecho is fine, even if it "only" shows ADS-B and FLARM. For looking at traffic at a far away place on the ground, it's not too useful.
My use case is from time to time I'd like to see the traffic flows around a destination airport during my flight planning phase, on the ground. True, I can do this another way, but I did get used to this when using FF, and having now switched to SD, I wondered if it was possible to add this feature. If not, not a huge problem. Just asking. open your FlightRadar24 app?
By rv8ch - 4/22/2022 6:53:13 PM
+x+x+xIn my corner of Europe, I can barely get a single MET update via 3G above 2500ft. 4G disappears lower than that. If you really want live trafic in the plane, get a SkyEcho. In flight, the skyecho is fine, even if it "only" shows ADS-B and FLARM. For looking at traffic at a far away place on the ground, it's not too useful.
My use case is from time to time I'd like to see the traffic flows around a destination airport during my flight planning phase, on the ground. True, I can do this another way, but I did get used to this when using FF, and having now switched to SD, I wondered if it was possible to add this feature. If not, not a huge problem. Just asking. open your FlightRadar24 app? Good suggestion!
By rv8ch - 3/21/2022 1:04:10 PM
Not sure if this is in there, or if it's already been discussed, but is there any interest in overlaying internet traffic info onto the SD map? Perhaps getting a feed from adsbexchange or pilotaware or another provider? Thanks!
