VFR Reporting points as triangles option?
http://forums.skydemon.aero/Topic34686.aspx
By rvt - 2/24/2022 7:41:32 PM
Hey,
is it possible to setup closed and open triangles for reporting points instead of the circle with a V?
I keep reading this as reporting point Victor as the V in the circle is much more clear to read than the reporting point in magenta next to it...
Another option but possible less desirable is put the reporting point in the circle instead of the V?
R.
By KimW - 2/24/2022 9:54:39 PM
Hey,
R.
Open triangles are already depicting IFR reporting points with magenta text in the same place as VFR reporting points. I would expect Tim to be very cautious about changing symbols on maps, as they should be, as this is impacting all other users being familiar with the symbols used. I'm sure you will get used to the symbol quite soon.
