Missing radar frequency
http://forums.skydemon.aero/Topic34424.aspx
By publicom - 6/27/2022 7:48:18 AM
The radar frequencies are missed a lot. And it's not consistent. Venezia Radar is there, also Milano Radar. Padova ist missing and for Germany I can't find any Radar Frequencies at all (except at the Airports).
By grahamb - 6/27/2022 8:09:18 AM
That’s probably because for VFR outside controlled airspace the call sign is ‘Information’.
By publicom - 6/27/2022 8:11:50 AM
That's why I'm talking about VFR inside controlled airspace.
By Tim Dawson - 6/27/2022 11:00:11 AM
We list frequencies against airspace where the AIP defines them. In German the DFS have encouraged us NOT to list the radar frequency against controlled airspace as they want you to contact the relevant FIS first (for which we provide the frequency) who will give you the appropriate frequency to gain access to the controlled airspace.
By publicom - 6/27/2022 11:18:59 AM
Ah, ok. Thank You for the Information. It's a pity because who would contact radar initially VFR? But if they think...
It would be even a much greater help i. e. in Italy, where you have to change frequency sometimes every couple of minutes.
By Tim Dawson - 6/28/2022 9:27:11 AM
Can you give an example in Italy where the SkyDemon data falls short? I can check that we are showing whatever the AIP advises.
By publicom - 6/28/2022 9:56:13 AM
Yes, like philippauer said: Padova Radar.
Basically most Radar frequencies (also german) are in SkyDemon if they are responsible over a CTR or CTA. Then they are listed in „Whats here?“. Also Munich Radar can be found, but not in its area, but only if tapping on Munich Airfield.
That is the Problem: Milano Radar is over Verona CTR – Treviso Radar is over Treviso CTR. Padova is in between, but has no special Airfield, that would list its Frequency, as even Padova Airfield is under Treviso Radar.
The Advance to have all local Frequencies in the RADIO-Tab would be to check, if understood correct. Italian English is special...
By Tim Dawson - 7/4/2022 8:49:56 AM
Ok... so what is it?
By publicom - 7/4/2022 8:57:16 AM
I do not understand Your Question. You were referring about Padova CTA, but I do not know anything about this CTA.
It's about having radar frequencies in SD in general and Padova Radar in special.
By Tim Dawson - 7/5/2022 11:26:31 AM
We include frequencies for controlled airspace in SkyDemon where the AIP clearly allocates them. In Italy this is often not the case. I thought you wanted to help us allocate them in the case of Padova controlled airspace but I must have misunderstood.
By philippauer - 1/2/2022 4:39:34 PM
I am a German pilot and often fly in Italy (north and middle).
In italy I miss Padova north and south radar frequency and in Germany Munich radar frequency - SkyDemon show me just the information frequency.
Any ideas Smile?
Best regards
Philipp
By Tim Dawson - 6/30/2022 11:26:36 AM
I've just spent some time studying AIP Italy ENR 2.1 and although Padova Radar exists there with a frequency of 119.175, there isn't any information about its coverage or when people are expected to use it. By contract, the FIS we do have geographical coverage for. Where are you getting the information about where to use this frequency?
By publicom - 6/30/2022 11:40:49 AM
I was requested to call them by Information. If I remember right, it should have been somewhere in Padova 3, 6, 8, 9 CTA.
This was already a topic here.
By Tim Dawson - 7/1/2022 11:58:29 AM
Just so I am clear, you're saying the frequency for Padova CTA access is always 120.725?
By publicom - 7/1/2022 12:03:31 PM
No, I do not recognize the frequency.
