By GregBush - 11/17/2022 12:14:07 AM
sure, SD should be able to MIX data: navigate with onboard GPS, and add traffic received via GDL90 from a second device (which runs Safesky). Why? Many reasons. The main one is a safety issue: if the second device running Safesky should fail (overheat... out of battery... who knows), SD won't navigate any more. IN CASE a pilot understands the message while flying "device offline for xx seconds" at all, he might switch back to planning mode, then back 'go flying' and select local GPS. I don't want such an issue as a pilot. Fly the plane! Most of my fellows might not understand whats going on. Suddenly navigation is lost.... any complex airspace around.... they'll burn their available adrenaline quickly. Other navigation software, such as Air Nav Pro, EasyVFR or ForeFlight have this feature, so why not SD. Safesky is able to send just traffic, not GPS, as it does with the mentioned Apps already. Please nobody say: "we don't like Safesky at all... we don't know about latency...it's not reliable". Agree on a possible latency issue. A few seconds? Anyway. Warning apps will IMPROVE safety. Worst case there is no improvement, but NEVER a degradation. Latency or not. Pilots will appreciate any means to improve traffic awareness. --
Long story short, feature request: use built-in GPS for navigation, add traffic data rec'd via GDL90. Other pilots might want the same feature. Thanks!
By Tim Dawson - 11/17/2022 11:42:43 AM
If your traffic device fails, you can press the ? button in the green warning banner that tells you so. SkyDemon will then offer to revert to Location Services so you can keep navigating. It's two touches of the screen. If and when SkyDemon detects your traffic device has started working again, it will silently switch back so you're receiving traffic.
There's no need to switch back to planning mode or interrupt your log.
By tnowak - 11/17/2022 1:31:41 PM
FYI, SkyDemon has told me that you can't have SafeSky and SkyEcho 2 connected at the same time.Something to do with them both using the same protocol for data transmission. That is a shame, but I want to keep my real time reception of ADS-B Out and FLARM data.
I don't suppose there is a future, possible, technical solution to allow both system to integrate with SkyDemon? Tony
By Ridgeskimmer - 11/17/2022 2:01:30 PM
Yes you can! I have been for a long time. I use SafeSky linked to SkyEcho which is then connected to SkyDemon. It works very well indeed
By GregBush - 11/17/2022 6:20:20 PM
Hi Tim, thanks for your reply! I had not been aware of this feature. Hopefully more experienced fellow pilots are. Still I am wondering why you don't want to offer a third option: use location services for navigation, and merge traffic from 3rd party device. Navigation WILL be more reliable: tight connection to built-in GPS, not affectable by poor Wifi. Less wifi traffic. No latency. Just independant of any unknown 3rd device. Mentioned competing Apps picked the idea. So why should SD stay behind. Greg
By Tim Dawson - 11/18/2022 10:07:12 AM
We simply haven't seen many people asking for such a solution. Of those that have, most were concerned (like you were above) with the situation where the device fails and you're left without navigation services. We addressed that with a fallback feature, which even reconnects to your device when it's available again.
We prioritise feature development by the desire in the community. If it transpires that there's a good body of people who want to merge traffic from one particular product with GPS data from location services, then that's something we would put our minds to. We are not there yet.
By Freccia - 11/18/2022 3:23:05 PM
Hi, I have tried to fly a couple of times with SD using the Garmin GLO2 as a GPS source. It all works great with an Android tablet.
Now, if I wanted to integrate SafeSky to SD, would I just have to install the app, run it and see the traffic on SD?
Sorry if the question sounds silly, but I'm not very experienced.
Thank you.
By Ridgeskimmer - 11/18/2022 3:30:46 PM
You set up the connection to SkyDemon in the SafeSky settings. It’s fairly straightforward. You need the bought version of SafeSky
By Freccia - 11/18/2022 4:06:36 PM
+xYou set up the connection to SkyDemon in the SafeSky settings. It’s fairly straightforward. You need the bought version of SafeSky If I have not misunderstood, SafeSky does not show "all" traffic, but only that of those who have installed the app and are using it. It's correct?
By Ridgeskimmer - 11/18/2022 4:12:39 PM
Incorrect. Go on the SafeSky website. It tells you all it sees on there but much more than just others using SafeSky
By tristan - 11/21/2022 10:44:21 AM
Hello pilots,
Yes, SafeSky sends to SkyDemon traffic from all SafeSky pilots, but also from all the aggregated traffic (about 15 sources, including FLARM, ADS-B, some MODE-S, PilotAware, FANET...)...
(Note that regarding FLARM, pilots don't need to pay the £40 yearly subscription to decrypt the traffic in SkyDemon, since the traffic is already sent decoded to SkyDemon from SafeSky.)
When used along side with SkyEcho2 or any other eConspicious devices, you get the best of both worlds on SkyDemon: air2air traffic from SkyEcho show up on SkyDemon as normal, plus when in the range of internet connection (78% coverage up to 5000ft in the UK), SafeSky adds up traffic that SkyEcho does not see.
Fly Safe everyone
By Ridgeskimmer - 12/20/2021 8:50:49 PM
I'm a big fan of using technology to enhance flight safety and particularly in the area of conspicuity. I've been doing a lot of flying lately using Pilot Aware, Sky Echo and SafeSky. The most contacts you will see is using Pilot aware but Pilot aware does not put out ADSB if you need it to do that. The next best is Safesky and finally the least you will see is using Skyecho with contacts showing on Skydemon. Now when i use Safesky alongside Skydemon using the GDL90 option then brilliant I have all those Safesky contacts showing on my Skydemon app. However to do that I have to use the GDL90 device option when i "Fly", ie my phone as the GPS source. The problem now is if i loose my phone signal then Skydemon doesn't know where it is. So to my question and point! Can Skydemon allow us to have Skydemon traffic showing using the GDL90 protocol but allow us in the app to use say Skyecho for the GPS? This would be a perfect sollution at a very affordable price to enhance flight safety. I'm told you can do this Skydemon but are possibly being a little reluctant to do this as you don't like the use of mobile phones for this purpose? Please correct me if i'm wrong?
I have been using Safesky for months and it is brilliant. I see aircraft where they are and not where they were 30secs ago and for my kind of flying around the UK at up to around 3000ft have never lost 4g mobile phone coverage. Currently i run Safesky on a seperate ipad on other side of my cockpit and it works a treat tethered to my phone but it would be so much better running inside Skydemon. Please look at allowing this integration into your software using seperate GPS as it can only lead to enhanced flight safety. I would ask others if you feel the same to please support this post and if you haven't already tried Safesky then download it and give it a try, it's free! However if you want to be able to use it in Skydemon then there's a modest yearly fee of around £25 i think.
By FlappingTiger - 1/27/2023 2:58:16 PM
Hi Tristan
Thank you for your very interesting post and link to the Flyer article which I read.
So far I'm flying using SkyDemon connected to Sky Echo II. Can you briefly explain your concrete connection setup if you add SafeSky to the mix? I read in the Flyer article that both SafeSky and SkyDemon (the devices they are running on, respectively) can be connected to Sky Echo at the same time and exchange data through that connection. Are you using it that way or in a different setup? I assume SafeSky needs an Internet connection to a) generall work and get the desired data and b) feed the data to Sky Demon (or does it do that locally over the Sky Echo Wifi as well?).
For Sky Demon I use an iPad Mini 5 and the iPad connects to the Sky Echo II WiFi (no Internet over that connection, obviously). What's the best setup now to add SafeSky? Should it run on the iPad as well and if so, does it work being connected to Sky Echo via WiFi and still have Internet connection for SafeSky via the mobile network? The Flyer article suggests you can also run SafeSky on your Smartphone with mobile Internet connection and have both the Smartphone and the tablet be connected to Sky Echo over Wifi and that should work.
Sorry for all the questions, I'm really excited about combining Sky Echo and SafeSky for traffic information (and GPS from Sky Echo) in Sky Demon.
Happy flying!
By tnowak - 1/27/2023 6:34:45 PM
I will also be interested to know how SkyEcho2 and SafeSky can be run concurrently.I run SkyDemon on my Samsung smartphone and connect to SkyEcho 2 via WIFI. I also have the additional subscription to receive FLARM data from my SkyEcho 2. I did ask last year about how to connect SafeSky and SkyEcho concurrently but SkyDemon tech support said: "It’s worth noting that it’s not possible to use Safesky and the SkyEcho in SkyDemon at the same time".
By Ridgeskimmer - 1/27/2023 7:38:11 PM
I’ve been doing what you are both wanting to do for a long time. Works great. PM me for my number and I’ll talk you through it. Cheers
By FlappingTiger - 1/28/2023 9:44:05 AM
+xI’ve been doing what you are both wanting to do for a long time. Works great. PM me for my number and I’ll talk you through it. Cheers Thanks for offering individual support! I played around with the Sky Demon, Sky Echo and SafeSky combination and indeed got it to work quite easily. I incorrectly assumed that my tablet can't connect to Sky Echo via Wifi and still access the Internet via cellular mobile network in parallel. Sky Demon support is technically correct that you can't have Sky Demon receive GPS and Traffic from both Sky Echo and SafeSky as you have to choose one when you activate flight mode. However, Safesky can connect to Sky Echo and combine its own traffic information with Sky Echo data and feed everything to Sky Demon.
The following setup seems to work for me: Sky Demon and SafeSky (premium for Sky Echo connection and data feed to Sky Demon) installed on the tablet (iPad Mini 5 in my case). Connect the Wifi to Sky Echo. At the same time you need cellular mobile internet connection in the tablet/device. Once connected to Sky Echo over Wifi you should verify that despite non-internet Wifi connection to Sky Echo the tablet can still access the Internet through the cellular connection. SafeSky configured to use Sky Echo and share traffic data to Sky Demon, automatic software detection turned on. Enable 3rd party device GDL90 in Sky Demon settings and choose it when activating flight mode in Sky Demon. Activate flight mode in SafeSky ("Take off") and let it run with location permission in the background. Now Sky Demon should have GPS, SafeSky traffic and Sky Echo traffic data altogether. In SafeSky flight mode you can check with green button if the connections (SafeSky network, Sky Echo, Sky Demon) are working. On the other hand, Sky Demon would show a "waiting for device" message if it doesn't the the GPS/traffic data stream.
What I don't know yet at the moment: in case there is no cellular mobile data connection, does Sky Demon still get the Sky Echo traffic from SafeSky or not if SafeSky doesn't have a working Internet connection. I suppose yes but couldn't verify it so far. Will simulate it by disabling mobile data for SafeSky when I get to it (need Sky Echo traffic in range to verify).
In the Flyer article they suggest that a slightly different setup should also work, presumably for the situation where your Sky Demon device/tablet doesn't have cellular mobile network. They suggest to connect both your Sky Demon tablet/device and your other device with mobile Internet access to the Sky Echo Wifi and run SafeSky on the device with Internet access (similar like above but Sky Demon on a 2nd device without Internet). They suggest the SafeSky-SkyDemon data link still works through the Sky Echo Wifi connection if both devices are connected to it. I haven't tested it, maybe someone using it this way could confirm in this thread if that setup would also work. I'm going for the other option with both applications on the same tablet/device with the cellular and Wifi combination.
Happy flying!
By Ridgeskimmer - 1/28/2023 10:27:06 AM
To use it as you wish you connect SkyDemon to SkyEcho when you “Fly”. SafeSky is connected to SkyEcho separately. It’s all done in the SafeSky settings. As I said PM me if you wish
By Robert H - 3/14/2023 12:18:32 PM
You can also have a look at "air traffic observer" which is an external unit using the GDL90 protocol. From their website:To determine your altitude and difference towards other traffic it will use the onboard pressure sensor. The pressure is used to calculate your pressure altitude (QNE).
It is a great little unit, and cheap. Provides ADS-B in as well as traffic over internet as long as your phone have an internet connection. Works well with skydemon.
I have no relation to the company more than as a customer, just think the unit is great and the customer support (just one person as far as I understand it) is fantastic.
By jacoby - 8/15/2025 1:49:55 PM
Just a quick note to add to this useful thread about getting SafeSky to supplement SkyEcho traffic shown in SkyDemon.
The process as described by FlappingTiger worked for me too. I'll recap my steps here in case it helps anyone else wanting to get this combo going:
1. Turn on Sky Echo 2. Connect your iPad to the Sky Echo wifi 3. Start SkyDemon, Fly with Sky Echo 4. Connect your smartphone (during flight it can stay in your pocket!) to Sky Echo wifi 5. Start SafeSky (PAID version which as RidgeSkimmer points out is needed to allow traffic sharing) 6. Configure SafeSky "Navigation Software" with Enable Traffic Sharing to SkyDemon. 7. Configure SafeSky "External Traffic Device" with SkyEcho 8. Configure SafeSky "My Aircraft" with the correct ICAO unique hex code 9. "Take Off with SkyEcho" in SafeSky. 10. Now SafeSky supplements the native SkyEcho traffic with its own where possible.
A few observations:
1. When I ran SafeSky on the same old-ish iPad as SkyDemon, it kinda worked but then froze shortly after take-off. 2. Running SafeSky on my smartphone fixed this problem, and the iPad SkyDemon shows its traffic just fine. 3. When running SkyDemon, I choose "Fly with SkyEcho", not "Fly with GDL 90 Compatible Device". I cannot explain exactly why this works and SkyDemon aren't too keen on engaging in technical explanations - but it works as RidgeSkimmer says, and also means the Sky Echo control menu item is retained in SkyDemon while flying (e.g. to turn ADSB-Out off and on). One possibility is that the "Take Off with SkyEcho" option in SafeSky causes it to broadcast its UDP packets on the SkyEcho's standard UDP port, and SkyDemon can't tell the difference. But that's a wild guess. 4. I suspect Android tablets and newer iPads may be better at multitasking, meaning smartphone not required. But I still like the idea of splitting the SafeSky processing load off to a different device (that's the networking/computer nerd in me I guess).
Thanks to FlappingTiger for the useful post detailing all this in the first place, much appreciated.
By tnowak - 8/16/2025 7:23:35 AM
+xJust a quick note to add to this useful thread about getting SafeSky to supplement SkyEcho traffic shown in SkyDemon.
A few observations:
Thanks to FlappingTiger for the useful post detailing all this in the first place, much appreciated. There is an issue if trying to do this using an Android smartphone. The phone's Android OS won't allow a mobile data connection when the WIFI link (to the SE2) is active. I haven't been able to find a working solution to this issue for Android users. I am now using the new Safesky Aero Tracker which connects via Bluetooth.
By jacoby - 8/16/2025 12:26:23 PM
+x+xJust a quick note to add to this useful thread about getting SafeSky to supplement SkyEcho traffic shown in SkyDemon.
A few observations:
Thanks to FlappingTiger for the useful post detailing all this in the first place, much appreciated. There is an issue if trying to do this using an Android smartphone. The phone's Android OS won't allow a mobile data connection when the WIFI link (to the SE2) is active. I haven't been able to find a working solution to this issue for Android users. I am now using the new Safesky Aero Tracker which connects via Bluetooth. That is an interesting observation, I imagine this behaviour must vary by device.
My Pixel 7 happens to work in this configuration, successfully connecting to LTE for internet and to SkyEcho WiFi at the same time.
By tnowak - 8/18/2025 3:39:06 PM
+x+x+xJust a quick note to add to this useful thread about getting SafeSky to supplement SkyEcho traffic shown in SkyDemon.
A few observations:
My Pixel 7 happens to work in this configuration, successfully connecting to LTE for internet and to SkyEcho WiFi at the same time. I know that this seems like a stupid question, but are you sure? For a few years I thought I had a good mobile data connection, when using my SE2. That was until trying to test something and I realised that SkyDemon wasn't receiving real time weather updates when the SE2 was connected.. If the Pixel 7 really does work then that is really good to know. I thought all Android devices were, more or less, the same..
By jacoby - 8/18/2025 8:45:13 PM
+x+x+x+xJust a quick note to add to this useful thread about getting SafeSky to supplement SkyEcho traffic shown in SkyDemon.
A few observations:
My Pixel 7 happens to work in this configuration, successfully connecting to LTE for internet and to SkyEcho WiFi at the same time. I know that this seems like a stupid question, but are you sure? For a few years I thought I had a good mobile data connection, when using my SE2. That was until trying to test something and I realised that SkyDemon wasn't receiving real time weather updates when the SE2 was connected.. If the Pixel 7 really does work then that is really good to know. I thought all Android devices were, more or less, the same.. I will double check this Thursday when I am flying again, and report back with either a confirmation or an apology! I know from previous experience how easy it is to confuse configurations when switching around to make something work...
By jacoby - 8/22/2025 9:13:24 AM
Yes I can confirm that this combination works following a careful test yesterday:
- SkyEcho installed and switched on. - iPad Mini running SkyDemon connected to SkyEcho WiFi (Go Flying, Use Avionix SkyEcho 2) - Pixel 7 phone running SafeSky connected to SkyEcho wifi and using cellular internet (Take Off, SkyEcho)
SafeSky-detected traffic appears on SkyDemon. I configured SafeSky to prefix traffic with 'sy' so it was possible to see which traffic was directly detected by SkyEcho (ADSB and FLARM) and which was detected by SafeSky (pretty much anything else).
The SafeSky traffic came and went depending on cellular, and both persons on board connected their SkyDemons for the same view.
I think there is a lot of variability in device capabilities, making the exact device choice important. For example, while I am lucky that the Pixel 7 works in this way, I am unlucky that the old iPad mini (which also has cellular) is too underpowered to run both apps reliably!
By flyflo - 2/23/2026 12:33:12 PM
I don't think the solution with multiple open apps is very sophisticated anyway.
By tnowak - 2/24/2026 2:48:16 PM
+xI don't think the solution with multiple open apps is very sophisticated anyway. If you buy the new SafeSky / Avionix Aero Tracker you don't even need to run SafeSky, apart for initial configuration.The Tracker connects directly to SkyDemon (or other EFBs) via Bluetooth. It works very well...
By BartH - 4/6/2026 12:00:45 AM
Guys,do You also have problems with iPad overheating while flying with SkyDemon and SafeSky connected together. I had this problem on older iPad Mini 4, changed to latest Mini 7 recently. Now while sun is out again even in Norway, I can again feel the heat and experience the whole system slow down due to overheating. When I run SkyDemon alone, it's normal. SafeSky - more heat than normal. Both - then the overheating starts. I'm worried that when in southern Europe in summer - that solution might be totally unusable.
By tnowak - 4/7/2026 10:45:59 AM
+xGuys, do You also have problems with iPad overheating while flying with SkyDemon and SafeSky connected together. I had this problem on older iPad Mini 4, changed to latest Mini 7 recently. Now while sun is out again even in Norway, I can again feel the heat and experience the whole system slow down due to overheating. When I run SkyDemon alone, it's normal. SafeSky - more heat than normal. Both - then the overheating starts. I'm worried that when in southern Europe in summer - that solution might be totally unusable. I would post that question on the SafeSky forum and get feedback from the SafeSky developers..
By tnowak - 2/3/2023 8:04:54 PM
One thing to bear in mind is that SafeSky app users transmit their GPS derived altitude.Aircraft equipped with transponders transmit their altitude with reference to 1013.2 So, on a day like today where the QNH is 20 hPa above 1013.2, the difference in transmitted altitude between GPS derived altitude and "transponder" altitude is around 600 ft. So, the clever algorithms that SkyDemon uses to warn of potential collision risks aren't going to work very well... SafeSky is aware of this issue and is, I believe, trying to figure out how to fix this issue...
By GalaxyzA11+ - 5/2/2026 9:45:27 AM
Hi Barth, Your observations are alright. The first things to consider are the protective case that hinders heat dissipation and the direct sun exposure. Software and hardware issues come only after that.
But, surprisingly, many of us still hope that our tablet will not overheat when exposed to the summer sun ;-)
