Android - Flight Planing - In Pilot log TAS is always cruise speed, even on climb-legs
http://forums.skydemon.aero/Topic34284.aspx
By NNR - 11/24/2021 2:34:18 PM
Ah, OK, thanx for the quick reply!
By NNR - 11/24/2021 10:43:33 AM
Dear Sky Deamons and pilots,
I have the problem, that I defined for my aircraft two cruise-profiles (normal and fast), as well as climb and decent profiles. If I plan a route now, my three first legs should be climbing, which is shown in the altitude profile in the bottom, but if I create the pilots log, the Altitude is always given with the altitude of the final cruise altitude, which is reached only 2 legs later, and the TAS is always given in cruise speed, although it should be slower in climbing. I would expect SD to insert this automatically, but I cannot even manually change the leg to cruise. I can only chose there between the two different cruise-Profiles. Why is that? And is there a way around this?
