Go flying w/out route plan
http://forums.skydemon.aero/Topic33554.aspx
By lve0200 - 5/30/2021 4:22:33 PM
Hi All,
I'm Hans, living in France and testing Skydemon vs. SDVFR. What is the philosophy of Skydemon, when I just want to fly a few circuit patterns or a short excursion into the training area and back? When I start Skydemon, it asks for a route planning, but I would like just go & fly, leaving Skydemon as moving map, but also activating the ILS and circuit path indication on the map. I saw the moving map and the traces (log), but I couldn't find any way to activate the ILS.
Obviously, up there in the air, I have other things to do, rather then fooling around w/ displays. I'm therefore looking for a guideline "how to use Skydemon w/out route planned".
Best Regards
hk
By Tim Dawson - 6/1/2021 8:59:31 AM
You don't have to plan a route at all, just open SkyDemon and press Go Flying.
As others have said, you can "plan" a local flight from one airfield, which is a simple action and might be best for your needs in the circumstances you've described.
