Hi there!
I flew to Borkum (EDWR) yesterday using SkyDemon, and as I susually do, opened the DFS aerodrome map in the navigation screen after landing (great feature, by the way!!!) Unfortunately, the positioning of this map seems to be off by about 50-100m: the DFS map showed me having landed beside the runway, although I'm pretty sure I would have noticed... I checked afterwards loading the track into the PC version of SkyDemon, and see the same problem. The positioning of the aerodrome in the standard SkyDemon map is fine, as you can see from the two screenshots attached ( they show the same track, once with the standard map, and once with the DFS map superimposed).
And since I'm already at it: I was also in Juist (EDWJ). There I noticed that the DFS aerodrome map can be opened as PDF, but it cannot be superimposed on the nav screen. I suppose this is because of missing georeference data? Could it be fixed?
Thank you!
