+x+xI found a difference between the way Low Altitude Military Restricted Areas appear when planning a flight between the computer version and the IPAD version. In the first case, defining the flight departure, they appear clearly in the map, exactly as in the SIA site, but it is not the case in the IPAD version. I assume there is a mistake on my side on some parameter, but I cannot find it. Can somebody give me a hint about this ?
A picture would help, very difficult to have an idea about what is going on.
May be you have the week-end view on the Ipad.
I found the problem. Just a click to make the zones appear. Thanks !
I hope it will work when flying without having to make the click. Anyway, the most important is that they appear clearly when preparing the flight on the Ipad. A do not travel with the computer...
