Suggestion: Keep aircraft and waypoints synced
http://forums.skydemon.aero/Topic29029.aspx
By emporer - 7/23/2019 10:27:55 AM
I also work with several devices and it happened to me many times, that I lost waypoints or aircraft settings if i don’t immediately sync manually on all devices, thats a hassel and doesn't make sence.
PLEASE add Switches in setup for Auto-syncing of :
Routes, Waypoints, Aircrafts, Logs, General-Program-Favorites (did I forget something?)
than al folks will be happy. Thanks
By b3nn0 - 7/23/2019 11:47:57 AM
I agree, that would be superb.
Often, after a flight, I tune my Profile some more. Of course I forget to sync to all devices. When planning my next flight, I notice that I now have two versions for the same Aircraft and don't remember which one the newer is. Auto-sync would be perfect to fix that.
By efrenken - 7/23/2019 8:08:34 PM
+1 for autosync
By Tim Dawson - 7/24/2019 3:42:03 PM
We would love to do automatic sync, but the rules need to be different for the different types of things you can save to the cloud in SkyDemon. We discussed at great length the notion of automatically syncing planned routes between devices this year, or last year, and there were too many factors against it. Instead we improved the user interface so that it solved many of the problems users wanted auto-sync of routes to solve.
Logs is something different, and I would be in favour of automatic backing up of logs to the cloud after a flight. We have seen some users protest against this due to privacy concerns, and in fact those concerns conceivably stretch to any automatic syncing of any data, so it would need to be optional.
I'm in favour of automatic syncing of settings, but even on this thread somebody has made a perfectly reasonable objection to the notion of this happening.
The automatic syncing of aircraft profiles when they are updated is a nice idea too, albeit it wouldn't update all your saved routes which use that profile.
User waypoints in general is a feature which is due for an overhaul, and I'd like to better integrate the cloud at that point. Suggestions are, as always, welcome.
By emporer - 7/24/2019 4:25:56 PM
I repeat myself :
PLEASE add Switches in setup for Auto-syncing.
Than every user can decide which syncing-behavior he prefers.
By Tim Dawson - 7/25/2019 9:42:18 AM
As always, adding great banks of switches in the options is NOT correctly solving the problem. Detailed feedback on specific use cases is welcome. Let's focus on one type of syncing at a time, and have a discussion about the pros and cons, otherwise it isn't worth the discussion.
By Sky Painter - 7/25/2019 11:03:12 AM
Tim
I've always thought of the lack of an 'auto-sync' feature as no more than a minor, but irritating inconvenience. Nevertheless, I've also always considered such a feature to be desirable, but couldn't make up my mind as to how it should be implemented. Having given the matter a great deal of thought, may I make the following suggestion:-
1. Make Auto-Sync a user selectable option in Settings;
2. If a user selects Auto-Sync  they should then be presented with a list of check boxes so that they can then select which items in the list they would like to see auto-synced;
3. Needless to say, if a user selects auto-sync of Settings then the auto-sync settings themselves should be auto-synced.
I'm not a programmer, so have no idea how difficult this would be to implement, but I think that it would be an elegant solution to the Auto-Sync conundrum and would/should satisfy even the most demanding of users.
KInd regards
By ArnaudC - 10/1/2019 10:44:40 AM
I would be in favor of a user-selectable auto-sync.
By jfw - 10/2/2019 11:33:22 AM
I beg to differ. I want to be able to define what is synced and what not by device, auto-syncing the sync settings would not allow this...
By emporer - 10/6/2019 10:46:48 PM
i asked several times for it, they don‘t implement it, i don‘t understand why, maybe more user should start to complain!!!!!!!!!!!!!!!!!!!!!
By plume_tray - 10/7/2019 9:53:01 AM
Add me to the list in favour of auto-sync. Add on/off switches in settings to appease the few who are not interested.
Been using the software for years now, and manually syncing is a day to day annoyance and poses real risk to losing my data if not done properly.
I even raised my own feature request about this back in 2017 with 38 thumbs up in support: http://forums.skydemon.aero/Topic23791.aspx
By vfr-uk - 7/21/2019 10:18:04 AM
So if you make changes on one device it updates on any others.
