+xOk, I think we must be omitting from the map due to their sheer quantity. Would another way to insert one into your route help? I am imagining you could bring up the Leg Properties for the leg you want to split, then we could show an option to insert a waypoint into that leg, which would allow you to select the numbered waypoint. Would that help?
Hi Tim, I was able to have a look onto this on my last IFR flight.While in flight you can search for such a waypoint and the menu offers to insert it into the current route. The algorithm even picks the right route segment for the insertion. I was not aware of this feature which is absolutely sufficient for inflight editing since it is unlike the behaviour during flight planning, where it is not possible to select it or to add it to the route.
So my wish would be more that the search dialog in planning mode behaves in a similar manner to that during flight.
Best regards
Martin
