Controlling automated climb/descent profiles
http://forums.skydemon.aero/Topic2746.aspx
By T67M - 4/30/2011 4:57:26 PM
I was just trying out a flight from Redhill to LeTouquet to see how well SkyDemon coped with the stepped-climb required to remain clear of controlled airspace, and found that while I could control the climb to some extent, I couldn't get exactly what I expected without adding in a LOT of extra waypoints. The best I managed is shown below:
In particular, notice that the climb from 1400' to 2400' starts before Bough Beech not after it, thus causing the flight to enter CAS. Second, whereas I would like to step-climb (or even better, cruise-climb with SkyDemon suggesting a desired RoC in fpm) to remain just below CAS at all times, the actual profile created keeps me at 2400' all the way to LYD, then makes one long climb all the way up to FL054 (which, interestingly, is shown as 5400' despite the airspace being define as a flight level).
Am I doing something wrong, or is this something that isn't (yet) supported fully by SkyDemon?
Thanks,
T67M
By Tim Dawson - 2/23/2026 10:12:56 AM
How would you plan such vertical steps without inserting turning points in your route?
