SkyDemon Flight Planning
Favorites airfields
http://forums.skydemon.aero/Topic26339.aspx
By Martin Bech
6/28/2018 7:18:17 AM
If I plan a route from A to B and mark an airfield C as Favorites and then hit the Pin to route nothing happens? Even if I use the What’s Here on an airfield and go into Information, pressing the neadle and use Pin To Route nothing changes on the map? Have I misunderstand something?
Would it be possible to have Favorite airfields under the function Create Route?
By Tim Dawson
7/4/2018 10:39:15 AM
Favourite Airfields are nothing to do with a route. When you have favourited an airfield it's always present somewhere in the Airfields window so you can quickly access its information. Nothing should change on a map.
Does that help?
