By aircraft72 - 4/25/2018 9:22:50 AM
Hi there. I have a question. I used Skydemon last weekend for a VFR Flight in the Swiss Alps. Everything worked perfect. You have relay done a great Job for Switzerland. The only "issue" i had was that i got Airspace "C" Warnings above FL130. Skydemon did not recongnize that during MIL OFF Airspace C is going up to FL150. Its actually just about warnings. I am aware of the rule so i can easy click them away. However i was wondering if you will be able to adjust this or if there is a setting i can use? Another thing i saw is that the green line for Showing Nord of the Alps or South of the Alps from the ICAO Map is not shown in Sky Demon. This line is defining FL's during MIL ON-OFF and Weekends. Thanks to let me know.
By Tim Dawson - 4/30/2018 9:40:23 AM
There isn't a setting for things like this. Our charts show airspace as it's defined by the authorities, and if it's sometimes one level and sometimes another, we will show the more restrictive of course for safety. If you happen to know that under certain situations the level changes, you must use that knowledge yourself but it would be impossible to code that knowledge into SkyDemon in a way that didn't over-complicate the user interface and prove confusing under many situations.
