By pmkarlss - 4/11/2018 3:13:55 PM
When SD lost GPS signal and eventually re-gains the signal, it seems to issue a new flightplan from the poitn where the GPS signal was re-established. is there a way to get SD to continue to log on the existing flightplan - even if a few minutes of flights may be missing.
By Tim Dawson - 4/12/2018 9:51:09 AM
If you're seeing a connectivity problem window why you're flying, I suggest you turn off SkyDemon's attemps to connect to the internet. By default it's off, so presumably someone has turned it on for you. Look at Internet Connectivity under the Setup menu.
"Go Flying" is shorter than "Enter Navigation Mode".
