By Hetzenauer - 1/4/2018 7:22:40 PM
            Hi! Since most of the radio frequencies in Germany have already been changed by the 1st of January to comply with the 8.33-kHz-channel spacing requirements we have to use them right now. Some of the new frequencies can be found here: http://www.aeroclub-nrw.de/wpaero/wp-content/uploads/2017/12/1-1192-17_sig.pdf Others are published by NOTAM only... I downloaded the newest data today for SD but it seemes none of them were included in AIRAC 1801. When can we expect to have them changed? Thx in advance, Björn
            By Hartmut - 3/15/2018 6:42:18 PM
            I called the DFS and asked them how in the world someone should know of these new frequencies. This switch has been scheduled for decades, yet there is no organised way of information transmission. The best way is to call FIS and ask them for advice, yet these frequencies can't be dialed in often with the spacing set to 8.33khz.
  However, The DFS Manged to publish an update on the frequencies of most German small air fields: https://www.dfs.de/dfs_homepage/de/Services/Customer%20Relations/Kundenbereich%20VFR/05.03.2018%20-%208,33%20kHz-Umstellung/AIC_VFR_02_18_15MAR2018.pdf
  It may require a user account , therefore I'll try to attach the file and the addendum.
  Good flights. If anyone has the new frequencies for the German FIS sectors to share, let me know Since these frequencies had been published by such a late time, I don't think they'll make it into the printed maps. The official publishing date for those is end of March.
  It is like last year when the Czech republic moved to the 8.33 channel spacing - no map had the new frequencies, only SKYDEMON was up tpo dat! Thanks SKYDEMON , this is the way to go.
