By Xavier-FR - 2/12/2017 4:05:07 PM
Hello!
I do not see any aerobatics zones neither during the flight preparation not during the flight. I can see the parachute dropzones and the glider zones but nothing about aerobatics zones. Is it the same for you?
Thanks, Xavier
By tnowak - 2/22/2017 8:32:44 AM
I suggest the same solution you used to indicate the French "do not fly over" areas that are depicted on the charts as small red squares. Probably a simple symbol that looks similar to what the French use to depict the aerobatic areas would suffice. Tony
