Show class of airspace flying through in pilot log
http://forums.skydemon.aero/Topic21281.aspx
By flying_David - 1/26/2017 6:56:30 PM
When I create my pilot log, I always check for airspaces that I fly through and double check to have according actions planned before crossing or also plan B's for non-clearances.
I usually do that with a text marker and mark the airspace class of the planned leg on the left side, to make sure that I don't miss to get a clearance.
What I would suggest asa  new feature is the possibility to include a column called "Airspace class warning" that automatically displays if the planned leg runs through class A, B, C, D airspaces. Probably it is possible to configure which alerts I'd like to receive?
As shown below, a red sqaure with the letter D is shown, if the leg is planned within class D airspace (depending on the altitude and so on)
This would really help me in planning :-)
Thank you very much for thinking about and your response - thanks also for your great application!!
Best regards from LOWG,
‌David
