Problems with V2.0 sync
http://forums.skydemon.aero/Topic2084.aspx
By Baron von Mildred - 2/24/2011 5:20:02 PM
At first I could get the device to sync after upgrading to V2.0 on the pc . Another day, another a try, and the sync worked, except it overwrote the map already present. Then when booting SD mobile there is a message saying 'no maps installed' or words to that effect. Fortunately, I had a back up of the SD files from previous version, so I copy across the file that seems to be the map data file. Re-boot & the map is there, except it no longer shows any terrain. The airfields, airspace, dots for spot heights (no figures) are there, just no ground at any zoom level!
Have I missed a file somewhere or what?
By Baron von Mildred - 4/11/2011 10:11:47 AM
No, its just one click, I'm using blackberry again, so let's see what happens this time!
The sync problems I think are usual windows gremlins. Sometimes I can't sync to the sd card whether its in or out of the device, & end up copying files manually. Other times sync works fine!?
