+x+x+x+xThere is no reason (unless in the USA) to wait until transition altitude/level to set 1013/QNH. Once you're cleared to a flight level, set standard. When you're cleared to an altitude, set the QNH.
You’re right if you fly under control and get clearances. If you fly VFR and just decide to climb or descent above/below transition you may forget to adjust the altimeter. It happened once to me and I joined the traffic circuit with 1013 hPa set, which was far away from what it should have been that day. Some kind of alert would have come in handy in that situation.
...and if you don't fly under control, you have no reason to set STD at all. Just fly all the time on the 'best' QNH you can get.
Wrong. You have a reason by law.
I cannot find any reference in that thread to TA/TL but cruising levels only. Could you point me to the right direction?
Let's take a practical example: I fly from LSZH (TA 7000') to LSZS (TA 16000') VFR and planning to cruise 9500' (uncontrolled, class E&G). So good so far. Where/when I am supposed to change to STD baro and back in your interpretation? How is that helping me with proper terrain clearence over mountain passes?
