Flight Statistics
http://forums.skydemon.aero/Topic1702.aspx
By Max_UK - 1/18/2011 11:17:00 PM
A couple of minor points arose from a trip from Shoreham to Thruxton & back today. (Using the latest Beta release "SkyDemon 2 Preview", 17th Jan 2011)
Would it be possible to have the "Flight Statistics" info saved to be reviewed after the flight?
The present system produces useful flight times etc. but all is lost once the program is shut down.
Would be great to have (perhaps, a la Garmin) the record of the last ten flights saved.
The second (very minor point) is that scrolling ahead to check out an airport's data, can in certain circumstances, have a frequency obscured by the aircrafts position arrow.
This happened when cross checking Popham's frequency whilst the aircraft was to the South East. Large arrow, bottom right of screen, just where the frequency was being shown. (& yes, we did have a map & Pooleys as well Tongue)
No doubt this could be overcome by changing to track up? but is there another way round it?
Every thing else seems to be working very well & the program is improving with every release.
Regards from a SkyDemon fan,
Max.
By stevelup - 5/13/2011 3:11:28 PM
You can, but it requires a little bit of cunning Smile
The last four digits of the .flightlog filename shows the time the flight started.
If you then open that file in wordpad or notepad and scroll to the end and take the number in the first column, and divide it by 60,000 that will give you the length of the flight in minutes!
