Profile settings not synced across devices
http://forums.skydemon.aero/Topic17014.aspx
By tigloo - 9/8/2015 6:38:08 PM
I am a new user, apologies if this question does not make sense or has been answered before - I have looked in the FAQ and briefly through this forum but did not find a solution.
I registered today and started planning a flight on my Windows PC using Internet Explorer. I changed some settings (home airfield, map options) and at some point stopped planning. I then downloaded the app on my iPhone and found that it did not remember any of my settings. So I re-entered home airfield, continued to play around and at some point switched to my MacBook. Starting the web planning in Safari I again found that settings were reset to defaults (home airfield and other adjustments gone).
How can I make my settings persistent so that they are automatically available on any device I use SkyDemon?
Thanks!
By Tim Dawson - 9/28/2015 9:41:28 AM
Again, you should be using the cloud save and load tools, that's all that is required.
"Sync with SkyDemon Mobile" is for SkyDemon Mobile, our old software for Windows CE devices. Presumably, you are not using that.
