By FlyingOtto - 8/27/2015 6:00:41 PM
| Getting WIN 8/10 Tablet to work on Skydemon using internal GPS | | | Having spent months trying to make this work on my Toshiba Encore, finally managed it… | | | Need to download a com port emulator that will convert the built in tablet GPS signal into one that comes from a COM port, so that Skydemon can see the feed. | | | http://www.centrafuse.com/us/localizer-5-gui-1-port-service | It cost me US$15 to get this.
If you're interested the attached may be of use.
By Pilot_Prune - 4/27/2016 11:08:40 AM
I wanted to use my Surface Pro 4 W10 with SD. After reading the forums and even with advice from a moderator it seemed that I needed either the Centrafuse software, which granted was only $15, or the equivalent from turboirc.com. I was tearing my hair out trying to get this combination to function with no success. It was only on a more general forum about using the Surface 4 with other road map software I read a post which simply said "you don't need extra software, just plug in your external GPS to the USB socket" (in my case a GlobalSat BU-353S4 from Amazon). So I did and it just worked fine, including with SD no problem at all !!
