Crossed out map on SD 3.2.10 (on PC, Win 8.1)
http://forums.skydemon.aero/Topic15030.aspx
By ckurz7000 - 4/24/2015 9:24:27 AM
So far SD has worked well on the PC. Today I noticed a strange behaviour: on larger scales than 1:1,000,000 (e.g.. 1.900,000), a lot of aeronautical detail vanishes and a big red X is drawn across the entire map. Zooming out beyond the 1:100,000,000 mark and the X disappears. However, at these scales some aeronautical detail is suppressed also because of the zoom level.
This problem has occurred out of the blue. I didn't update SD. I tried to fix this by updating the maps but that didn't help either.
Thanks for the help, --Chris.
By ckurz7000 - 4/27/2015 2:53:49 PM
Hi Tim, for some reason I can't send you email. The system will block me and tell me that I don't have permission for that...???
Anyway, here is the informaiton I tried to send you:
A tried it at 14:46 UTC and got the described red cross over the entire map extent.
The cross appears only if the map scale is larger than 1.1,000,000. As soon as I zoom out beyond that limit, there seem to be fewer details drawn on the map and the error doesn't occur.
Any help is appreciated, -- Chris.
