		| By Isaache - 1/12/2015 11:23:29 AM
 I have been seeing many posts in this form where people asks the data of a particular location to be amended in one way or another just to be told that you only trust the official/original source of information. For an application designed to be used in VFR this is, in my opinion, not an optimal posture.
 Let me explain why I think in this way. For what I have seen you use (as most of the applications that I have seen) the Airport Reference Point as the coordinates of the airport which are used to put the center of the airport icon on the vectorial map when the ARP was never intended to be used for that purpose, now let's take a look at an example, LESU (La Seu d'Urgell airport), this airport ARP is located at the very end of the runway (opposite of the apron and hangars), this means that in an emergency situation with low visibility it is going to be harder to spot something on the ground if the pilot executes a "Direct to".
 A similar thing can be said of some charts that I have seen that are outdated or providing very optimistic runway runs, as of today the best source of information are the current ortophotos of the local cartographic institutions which normally provide enough resolution to measure runway, lengths, widths, headers, and in some cases where precise DTMs exist derive accurate ortometric heights.
 Further more, given the fact that SD provide the wonderful pseudo ILS, are you sure you want to use as runway header coordinates the published headers or the intersection between the runway center line and the PAPI lights? In most cases (if not all) the pseudo ILS would point the pilot short of the runway if the officially published coordinates are used...
 Obviously I'm not expecting SD developers to manually review every airport however I do seem to remember a post or maybe a new where some developer (Tim?) said that SD was going to support community made inputs to update the aeronautical database, is this going to happen any time soon?
 I linked a file below my lines, is there any chance that some of it is taken in to consideration (the names of the airfields have the "isa" prefix so that I can easily differentiate from the stock airports)
 Regardless of my comments I do believe this app is a great tool.
 Isaac
		| By Isaache - 1/13/2015 4:36:56 PM
 I tried to send you an email but for some reason I can't use the forum to send you an email, it says something like the admin has disabled that feature in my account...
 Isaac
