By sasquotschi - 9/9/2014 5:00:00 AM
I'm just another guy who needs help enetring the data for the weight and balance envelope. It's about a Grob G109A Touring Motor Glider and I've already converted the moment to arm (se table below)
| Moment/1000 | Moment | Weight (kg) | Arm (kg) | | 22,8 | 22800 | 600 | 38 | | 31,4 | 31400 | 825 | 38 | | 42,1 | 42100 | 825 | 51 | | 30,6 | 30600 | 600 | 51 | But when i enter "38,600;38,825;51,825;51,600;" or "38,600,38,825,51,825,51,600" it always happens that some number get cut-off (e.g. 60 instead of 600) and i don't understand why. My weight units in skydemon are already set to kg.
Thanks so much for your help. I'll share the G109A Aircraft Profile once everything is done.
By sasquotschi - 10/8/2014 12:52:11 PM
Problem solved!
It was the missing ,00. It isn't very intuitive that you ahve to give the decimals even though they are 0  So the W&B String for my Grob 109A looks like:
"38,00;600,00; 38,00;825,00; 51,00;825,00; 51,00;600,00"
