By henrikl - 7/25/2014 8:45:21 AM
Hi, Would it be possible to create rules, by which skydemon could autoroute a vfr-route from point 1 to point to by omitting airspaces,that the pilot wants to avoid ? When i create a route, i will be warned, that the route will cross airspace D. Can't you create a ruleset, by which the airspace is avoided in a configurable distance ?
By micha@pa18.de - 7/26/2014 3:18:54 AM
If you want to have autorouting, you have to use POCKETFMS. But - I have used POCKETFMS before SKYDEMON was on the market - I like Skydemon more, because it is much simplyer to use in the air!
A good software has to be DAU DAU = in German "Dümmster angenommener User" "stupid constructive user" then its working with small stress!
I like SKYDEMON
Mike (FI)
