By smithgd - 4/13/2014 6:49:22 PM
Hi
Can anyone help me to do the following:
1) Declutter the airspace in plan view on the map. I know you can hide airspace above and below user set altitudes but how do you declutter it? For example around CPT/Blackbushe the airways Class A is shown even though it is higher than the minimum TMA class A. Is there a way to only show the lower limit which in this case is the TMA? If I switch to airways mode it appears to declutter a little bit, how do I get it to do that in VFR mode?
2) When printing a chart (right click anywhere) it brings up the print center but when I printed a chart the scale was wrong. When I plotted a route and printed it it was correct? Is there a way to select a scale when just printing a chart?
Cheers
Graham
By smithgd - 4/16/2014 9:20:27 PM
Thanks for the help Tim.
1) it's not just that airway it's any airway for example N615 from MID heading over EGLF which is above the 3500ft min TMA level.
2) thanks wilco
Cheers Graham
