By gallwood - 1/1/2014 10:16:00 PM
I am using Centrafuse Localizer on my Win 8.1 machines (one desktop, one ASUS Viviotab Smart tablet) in order to make my internal GPS sensor data available via a COM port.
The data is being presented via Localizer, but when SD navigation is started it crashes immediately. There is nothing in the event logs to explain the crash.
I have a screenshot of Localizer, which seems to be showing the type of GPS data it is presenting if it helps.
Graham
By rene - 11/3/2014 11:27:43 PM
David, I have a toshiba encore with W8.1 as well and had the same problems. What seemed to work for me was; install the lenove gnss driver; search for Broadcom BCM4752 GPS Driver on the lenovo.com support site. Further reinstall localizer as administrator, and then run it as administrator. Than go outside with clear view at the sky. Be sure both items in the upper right corner of localizer are green (indicating you have a virtual com port, and a gps fix). If both are green, start skydemon, set your com port in setup-gps navigation options. Be patient. If skydemon crashes, close it and start it again. Finally being outside helped me. Once a fix has been achieved, it (later) also worked inside (but not always!). So best is to have a fix before starting sky demon.
Hope this helps. Rene
