Lost flightplan for return flight SD PC
http://forums.skydemon.aero/Topic10395.aspx
By crackle - 10/6/2013 8:13:03 AM
I recently used SD on my PC to file a flightplan to LFAT and back, the night before a flight. The outbound FP went through OK, but when I sent the return the process didn't seem to complete after some time (5-10 minutes) so I shut down and repeated the process, with the same result. When I later checked in the list of plans filed, there were 2 return flights (I had changed the ETD time so they were different), so I cancelled one of them. However there was no flightplan found at LFAT for the return flight so it is probable, I think, that they did not get through. I must say, having to fill out the paper version to for faxing reminded me what a blessing the SD version is!
Any ideas what I could do better in the future?
Thanks again
Christopher
By Tim Dawson - 10/21/2013 3:22:30 PM
Perhaps there was a problem on our server between sending your flightplan, recording it, and sending the confirmation email to you. It seems unlikely but that's the only thing I can think of that would explain what you're describing.
