Aircraft Profiles
Can I email a saved Aircraft profile?
Liam Sandie
Liam Sandie
posted 5/29/2013 11:26:06 PM
Visits: 261
How do I email one to a friend who uses the same aircraft so he can use it in his skydemon?
Also is it possibel to upload to the skydemon database for others to use or are the standard ones just created by skydemon developers?
HeatherStrauss
HeatherStrauss
posted 5/30/2013 12:00:08 PM
Visits: 4
I tried many methods and finally came to conclusion that it is not possible (atleast for me). If someone finds any workaround to do it then do share here. It gives some SMTP error and port number mismatch, even though everything seems fine.
martial arts lesson
Liam Sandie
Liam Sandie
posted 5/30/2013 12:01:01 PM
Visits: 261
Where is the option?
posted 5/31/2013 9:32:18 PM
Visits: 15K
Hi
I've recently successfully emailed a saved aircraft profile to a friend.
Assuming you are using a PC/Laptop, after you've composed your email, click on the attachment tool/icon and n
avigate to My Documents\Skydemon\Aircraft find the appropriate file and attach it in the usual way. Your recipient should then download the file to the same location on their PC/Laptop.
If you or your recipient wants the aircraft file on your/their iPad/Android device, you/they should save it to the cloud from the PC/Laptop and then download from the cloud to the device.
Hope this helps.
Samsung Galaxy Tab A8 – Android 11.0 & SD
4.2.3
26200.7840
, SD 4.2.3
