Altitude deviation alarm / alert
James Pearce
James Pearce
Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)Too Much Forum (72 reputation)
Posts: 9, Visits: 8
Is there a way to set an alarm in SkyDemon for a predetermined altitude? Situation - I fly between 2 areas of controlled airspace with lower limits of 2000'. I usually maintain a 400' - 500' buffer but had a bit of a squeak yesterday in thermic conditions and lack of attention that got me to within 120' - Phew  😳. An alarm at 1700' could alert me well before I get close to the airspace. It's all down to me, I know but it is a feature I would use. Thanks, James.
TimT
TimT
Posts: 98, Visits: 92
Isn't this what airspace warnings do? I frequently get a "airspace 600 ft above". And presumably I would also get a "Entered controlled airspace" should I punch through that ceiling.
But I see what you want, you want a 'last reminder' just before you violate that airspace about. 600 ft vertically or so is too early for you. And once you are in, it's too late.
I can set an ATL Alert on my Garmin TXP. But that would be pressure ALT. In our neck of the woods, PA is always a bit lower than actual ALT, so that gives me that 100 or 200 ft buffer.
Edited 5/10/2026 4:35:35 PM by TimT
Posts: 655, Visits: 32K
TimT - 5/10/2026 12:38:52 PM
But that would be pressure ALT. In our nick of the woods, PA is always a bit lower than actual ALT, so that gives me that 100 or 200 ft buffer.
How can you say the PA is -always- lower than indicated altitude when the former is based on a standard setting, and the latter on the actual QNH?
On a day when the QNH is lower than 1013.25 hPa, indicated altitude will be lower than PA.
TimT
TimT
grahamb - 5/10/2026 3:02:35 PM
Hi Graham, in principle you are of course right. I was just saying that in my country ("in our neck of the woods") the QNH is almost always between 1020 and 1030 hPa. But you are right, this might be of little relevance to the OP. So never mind.
Back to the suggestion from the OP: What do you think of the request that on top of the already existing warnings "Airspace 600 ft above" and "You entered airspace", it was suggested that we need a second warning "Airspace 300 ft above"?
TimT - 5/10/2026 4:11:36 PM
What a lucky person you are, never having to suffer a near constant stream of Atlantic depressions!
Posts: 385, Visits: 2.6K
James Pearce - 5/9/2026 9:00:33 AM
Do you have the SD audio alerts connected to your radio/intercom/headset?
I do and find it invaluable when SD warns of "controlled airspace xx feet above".
The trigger appears to be when I start climbing, intentionally or unintentionally due to thermal activity.
I frequently fly between Southampton and Bournemouth where CAS is at 2000 ft. My aircraft is quite "light" so is affected by thermal activity.
I watch my altimeter carefully!
TimT
TimT
Let me clarify how this ALT Alert on Garmin Transponders actually works. I hadn’t used it of a while, so I misrepresented it in my above post. As you will see, this eliminates the issue of Pressure ALT vs QNH-based ALT:
The feature on my Garmin Transponder is called “ALT MONITOR”. It assumes that I turn it (the ALT MONITOR) ON when at the correct ALT. Thereafter it displays my deviation from the set altitude (e.g., “-90ft”) and further shows/sounds a “LEAVING ALTITUDE” alert if the deviation is greater than the deviation limit (default is 250 ft., but this can be changes during configuration).
So the OP James could use this feature the following way:
-    Assume controlled airspace above from 2000 ft ALT
-    James wishes to fly at 1500 ft ALT to maintain a safe buffer
-    Once established at 1500 ft ALT, turn on the ALT MONITOR
-    In case James inadvertently climbs above 1750 ft AGL, a LEAVING ALTITUDE alert will sound
GalaxyzA11+
G
Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)Too Much Forum (54 reputation)
Posts: 27, Visits: 2
TimT - 6/7/2026 9:40:46 AM
Ok this will do it for some pilot who want to set it mannually ... And then will probably forget to set it later ?
As you said first, the alert function "airspace above" does already exist in SD.
The user has to enable it in the settings.
It will provide several alarms, each time you climb again you will get a new alarm trigger.
You get a popup on the screen, and a vocal message over headset if you have bluetooth and chose vocal alert in addition of the popup alert.
It is automatic, btw you don't need to set it mannually for each level.
HTH.
