+x Zlin_Flieger - 4/1/2024 10:14:39 AMHello all,I have connected SkyDemon with Stratux via „FALRM with AirConnect“. The Stratux is equipped with a baro sensor. Is the altitude difference shown on other aircraft based on the baro sensor (flight level) or the GPS altitude?Best regards, Matthias
+x b3nn0 - 4/1/2024 11:01:58 AM+x Zlin_Flieger - 4/1/2024 10:14:39 AMHello all,I have connected SkyDemon with Stratux via „FALRM with AirConnect“. The Stratux is equipped with a baro sensor. Is the altitude difference shown on other aircraft based on the baro sensor (flight level) or the GPS altitude?Best regards, MatthiasNeither. It is based on YOUR altitude. If it says +0,1 the aircraft is 100ft above you and nothing else.If you want more detail, read https://github.com/b3nn0/stratux/wiki/Altitudes-in-Stratux-EU
