Sky Demon Losing Connection with Xplane
Tailwinds
T
Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)Too Much Forum (281 reputation)
Posts: 13, Visits: 18
Am I the only one with this issue by any chance? I'm using the latest version of SkyDemon app on my iPad and navigating the route on the desktop PC version of Xplane 11.The connection is constantly dropping and SkyDemon loses my position. it then comes back briefly only to disappear again. It does this constantly to the point I had to give up the flight.
I know my connection is good seeing as I'm at home using my home broadband.
fingertrouble
f
Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)Forum Member (43 reputation)
Posts: 5, Visits: 0
Hi Tailwinds,
I had the same issue. I solved it by setting a fixed IP address for my iPad (Settings/Network/iPhone,iPad) tick off ‚transmit to a single mapping app‘ and then setting the same IP in my WLAN router. Hope it helps, Fingertrouble.
Tailwinds
T
fingertrouble - 6/9/2020 8:36:17 PM
Hi Tailwinds,I had the same issue. I solved it by setting a fixed IP address for my iPad (Settings/Network/iPhone,iPad) tick off ‚transmit to a single mapping app‘ and then setting the same IP in my WLAN router. Hope it helps, Fingertrouble.
Hi,.. sorry for the late reply.
Thanks,..I'll certainly give that a try.
