SkyDemon Navigation
Live Internet Data when Flying - SkyDemon - Dynon SkyView
TouchTheSky
T
TouchTheSky
posted 1/11/2020 5:20:48 PM
T
Visits: 4.6K
I am afraid this is a well-known problem - I could use live internet data connection with my iPad when flying but when SkyDemon is connected to Dynon SkyView, this won't work.
From SkyView, my iPad gets the following automatic IP credentials:
IP adress: 10.191.1.1
Subnet: 255.240.0.0
Any idea?
stevelup
stevelup
posted 1/13/2020 8:43:28 AM
Group: Moderators
Visits: 4.9K
Assuming you're on iOS 9 or later, on your iPad, make sure 'Wi-Fi Assist' is turned on. It's in Settings > Mobile Data (Settings > Cellular in some regions) section.
Basically, it allows your device to continue using your mobile connection for data even when WiFi is present if the device determines that the WiFi is not offering a working internet connection.
This setting does default to 'on' though... so you're either still on an iOS lower than 9 (why?) or you've turned it off!
Edited
1/13/2020 8:49:29 AM by
stevelup
TouchTheSky
For Android the solution is the app Speedify, for iOS, I have no clue....
Johannes B.
1/11/2020 6:04:14 PM
Assuming you're on iOS 9 or later, on your iPad, make sure 'Wi-Fi...
stevelup
