Feature request: simulator P3dv4 as a third party device
theorave
t
Posts: 2, Visits: 0
I would like to use skydemon also for my simulator P3dv4. Would that be possible in the feature?
with greatings
Theo Rave
FlightDek
FlightDek
Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)Too Much Forum (699 reputation)
Posts: 8, Visits: 15
theorave - 1/31/2019 4:03:20 PM
with greatings
Theo Rave
I use SD with FSX us a small program called FlightSimGPS.  This outputs FSX location data in X-plane format.  As P3D and FSX are closeley related it might work for this too.
Dek
ArthurFuxake
A
Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)Forum Member (36 reputation)
Posts: 2, Visits: 0
with greatings
Theo Rave
The secret is a little application called FSX2Skydemon (not written by me, I just stumbled on it). It's available from: HERE
It works with both FSX and P3D including v4 by providing an X-Plane output to SkyDemon.
- Install FSX2Skydemon on the PC running P3Dv4.
- In Settings of FSX2Skydemon, fill in the IP of your iPad.
- In the SkyDemon app, change Setup/Third-Party Devices/X-Plane to enabled.
- On the right upper corner of SkyDemon on the iPad -> Go Flying/Use X-Plane.
- Run P3Dv4 – Job done!
theorave
t
Posts: 2, Visits: 0
ArthurFuxake - 2/21/2019 11:35:36 AM
with greatings
Theo Rave
Hi ArthurFuxake,
Thank you for your solution. It works realy great. Its really very nice.
Theo Rave
Joachim Gothe
Joachim Gothe
Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)Too Much Forum (78 reputation)
Posts: 11, Visits: 57
is there a way to send multiplayer traffic from P3D V4 to Skydemon ?
Achim
