Direct to could be a bit better
stuartforrest
stuartforrest
Posts: 59, Visits: 108
When you are using the gps mode in flight and you select the direct to function it should show you all the local navaids and runways etc instead of you having to type something. It should have those readily available based on your nearest to where you are.
G-FOZZ www.gotoair.com
Runways
Runways
Posts: 309, Visits: 1.6K
Or hold your finger on where-ever you want to go Direct and you get an option/ list of options. You only need to choose one. it is actually much better than Garmin. (Oh, sorry Garmin ...I did not mean to upset you...but technology is changing so fast!)
Very Newbytheway
DurhamTeaseAirport
