SkyDemon Flight Planning
Transfering data to Nexus 7
vpsj
vpsj
posted 5/10/2014 6:11:39 PM
Visits: 48
How do I transfer routes (file) and aircraft data from laptop (Win8) to Nexus 7 2013? I have tried a linking cable and also tried using a micro SD card to no avail
vpsj
vpsj
posted 5/11/2014 10:00:25 AM
Visits: 48
Thanks but WiFi almost unusable in rural village. Download speeds sometimes 0.2Mb/sec! and none on airfield.
Taigajoe
Taigajoe
posted 6/24/2014 11:02:21 AM
Visits: 69
You should install the NEXUS MEDIA IMPORTER from Playstore. After that you save your data to an USB-stick at your Windows PC. Then you connect this stick with your NEXUS and now you can copy the data from the stick to the SD Folder on your NEXUS.
Another way is use to use Bluetooth for transferring the files.
vpsj
If you have Wifi , then easyist option is to save to cloud, then...
DarkStar
5/10/2014 7:49:52 PM
Thanks but WiFi almost unusable in rural village. Download speeds...
vpsj
You should install the NEXUS MEDIA IMPORTER from Playstore. After that...
Taigajoe
