Small Sugestions
JoelJacob
JoelJacob
Posts: 13, Visits: 28
I am an happy user of SD for one year now.
I have small requests to include in the software :
(1) When a leg is selected on the map, select it in the route plan
(2) DELETE/BACKSPACE key should delete a leg when selected in the map
(3) Add a ruler tool to measure distance between two points (for example, when flying over sea it should be handy to know if you have to board a liferaft given the distance to the shore)
(4) Print centre, Pilot Log : option to add a blank "comment field" behind each turning point
(I suggest twice the number of pixels used for a leg line in order to be able to write something)
Thanks,
Joel Jacob
Re your 3rd item: there is a ruler functionality already implemented (iPad version). Simply tap the screen simultaneously at the two desired points and you get all the information you'd want.
JoelJacob - 8/14/2013 9:06:25 AM
ckurz7000 - 8/14/2013 4:53:37 PM
