IPAD 3 with seperate GPS
warwike
warwike
Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)Too Much Forum (169 reputation)
Posts: 1, Visits: 2
My first post also ... I have an iPad 2, WiFi only, recently upgraded to ios 6, and I just purchased a GNS 1000 external GPS today. The indicators on the GNS showed a good Bluetooth connection and GPS position received OK. iPad settings showed that the GNS 1000 was connected. However, I found that SkyDemon in flight mode was not recieving a signal, i.e. the aircraft symbol was Red. (To be precise, the symbol was Yellow for 5-10 seconds when entering flight mode, then went red permanently after that.)
I powered the iPad off and on and saw the same results. I spoke to Skydemon (who were REALLY helpful by the way) and they suggested a set of things I should try. Before starting on the suggestions, and for no particular reason, I turned the iPad off and on again and everything then worked - huh?
I can honestly say that nothing changed between the 2 power off/on cycles, so I can't see any logical reason it should have worked after the 2nd cycle, but that's what happened. I hope this helps someone out there.
ps I am evaluating the software, but now ready to buy. Great product and a great service guys, please keep doing what you're doing!
Ton
Ton
Posts: 9, Visits: 57
I was about to follow up the suggestions I found on the web when I saw that there is a software update available for the Ipad (6.0.1). After upgrading the software and do some test, the issue seems to be solved..pffff
Paul Mahony
Paul Mahony
Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)
Posts: 39, Visits: 424
Please can someone help me?
I have a new iPad2 (iPad3?) with wi-fi and 3G. I have SD installed on it and it works brilliantly.
Today, I bought an external "Garmin GLO For Aviation" GPS receiver as I thought it might be even more accurate and reliable than the internal iPad GPS receiver as it uses GLONASS & GPS satellites.
It says in the manual that is has been made for the iPad / iPhone, etc, and I had no problems pairing it to my iPad with bluetooth. I get a solid blue LED telling me that it is talking to the iPad and a solid green LED telling me it has found out where it is!
So then I decided to disable the internal iPad GPS in order to use the external Garmin GLO GPS. Therefore, I went into Settings - Privacy and disabled Location Services. The problem now is that when I try to open Google Earth for instance, it just doesn't find my location and asks for Location Services to be turned on. When I open up Maps, it wants me to turn on Location Services to allow Maps to determine my location.
When I open up SD, it asks me to go back into Settings to turn on Location Services. When I don't do this and simply open up SD in Flight Mode, I see a red aeroplane icon instead of my usual yellow one meaning that my GPS hasn't found my location.
The iPad and GPS receiver are still bluetoothed to each other and I have tried all the solutions listed in this thread such as switching the iPad off & on, doing a hard reset and resetting everything back to factory defaults. Now, I am at my wits end!
Are there any 'boffins' out there who can see what I'm doing wrong ....or not doing?
Thanks.
Paul
Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)Too Much Forum (77K reputation)
Posts: 593, Visits: 4.9K
Yep - quite simply, don't disable Location Services!
When you have your external GPS paired, it overrides the internal one.
Turning Location Services off... disables Location Services and no app will be able to get positional information.
Paul Mahony
Paul Mahony
Hi Steve,
Thanks for your prompt reply.
Purely in the interests of furthering aviation research - and not because I, in any way, doubted your profound words of wisdom(!) - I switched my iPad on, loaded SD and then selected "Go Flying". Sure enough, the 'plane icon was yellow as it started to use its internal GPS. Then I took my iPad down to the garage under the house where I was sure it could not "see" any satellites, closed the garage door and the little 'plane icon turned red signifying a loss of GPS reception.
Then I switched on the bluetooth GARMIN GLO and noted that, although it paired instantly with the iPad, there was a flashing green LED signifying that it, too, had no GPS reception and the iPad SD 'plane icon still stayed red.
Then, I got the household's C-in-C to take the GARMIN GLO and stand outside the garage door. Lo and behold, the GARMIN GLO's green LED became solid - signifying that it had locked-on to some satellites - and the SD's 'plane icon turned yellow again!
Not only that, but when I instructed her to 'make like an aeroplane' outside the garage (without sound effects, of course!), the SD 'plane icon started moving about on the iPad screen! Fantastic!
Conclusion: An external GPS receiver bluetoothed to an iPad does override its internal one and you do, indeed, have to leave "Location Services" enabled!!
Thanks again!
Paul
deebee
deebee
Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)Too Much Forum (241 reputation)
Posts: 2, Visits: 71
Ton,
Many thanks for this, I had exactly this problem and solution 2 solved it.
On a slightly different topic, does anyone know of an app that will give the satellite data such as you get with Garmins and Skymaps?
db
Edited 1/6/2013 11:31:21 AM by deebee
