SkyDemon on Ipad
David Johnstone
David Johnstone
Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)Too Much Forum (872 reputation)
Posts: 16, Visits: 602
I loaded Skydemon onto my IPad today. It is brilliant, only one minor glitch, I couldn't get the GPS to work
freddie0509
freddie0509
Posts: 6, Visits: 49
What a wonderful addition to the SD Family. Well done team.
I've loaded the App onto my iPad but ever so often get thrown out and have to reload the route. any ideas?
Robby
Robby
Posts: 16, Visits: 261
Hi Tim
Ipad version absolutely brilliant - especially in the cockpit. I'll be using the SD as a backup now.
Could you check the Aircraft set up area - I've got IPAD 2 on IOS 5. Although I can add equipment I can't add aircraft type or Aircraft colours. (no oprion arrows to select)
john123
john123
Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)Too Much Forum (167 reputation)
Posts: 5, Visits: 2
Worked great yesterday and plenty of brightness in the Sportcruiser in the sun.
David Johnstone
David Johnstone
g-egbs (12/02/2012)
Problem solved by the old fashioned method.
Delete the SkyDemon App & then reload.
Bingo. Works perfectly this time.
Thanks SkyDemon it's really the way to Fly.
David
cstone
cstone
Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)Too Much Forum (108 reputation)
Posts: 2, Visits: 3
Has anybody tried a combination of an iPad Wi-Fi with external Bluetooth GPS unit, like GNS 5870 and SD?
BR,
Jani, Finland
dansmusic
dansmusic
Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)Too Much Forum (906 reputation)
Posts: 6, Visits: 70
Hello All
I have an original WiFi Ipad (no internal GPS) and I use
it with a small external high performance bluetooth gps unit.
Works great with Skydemon.
Congratulations to Tim and the team.
Dan G
EGSJ
cstone
cstone
Posts: 2, Visits: 3
Dan, Could you please name the GPS device you are using with iPad wi-fi? Seems that Apple has several restrictions on bluetooth devices, so any BT GPS unit will not work with iPad.
Software is just great! Can't wait to get airborne with it Smile
BR,
Jani
EFTP
Edited 2/15/2012 8:57:13 AM by cstone
Posts: 593, Visits: 4.9K
I've tested it with the Bad Elf wired GPS and GNS5870 bluetooth one and they both worked fine.
Someone else has reported it working with the Dual XGPS150A. It should (in fact almost certainly will) work with any GPS that claims iPad compatibility.
Flyingscotsman
Flyingscotsman
Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)
Posts: 4, Visits: 36
I don't know how to start a new post, so perhaps I can reply to this. I have previously installed and used Skydemon on my IPAD2. I tried to synchronise the Ipad with my PC (Vista) without success. I can live with that, but, more disastrously, I can no longer open Skydemon at all on the IPAD. It says it is installed, but when I touch the icon it shows 'Skydemon' but immediately cuts off. Does anyone have any suggestions? Can you re-download an App to IPAD, for instance?
