SD on Mac with Parallels - help!
ffg
ffg
Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)Too Much Forum (610 reputation)
Posts: 8, Visits: 16
Can anyone help with this setup - I run SD on a Macbook Pro with Parallels.
Lately it has been getting hard to get SD to open. I open Parallels, login to Windows 7, double click on the SD alias. I get a little blue circle for a couple of seconds, then nothing. Up to today, i would wait a while (frustrating, I want to go flying!) and then try again. SD would usually open, and i would find I have 2 versions of the programme running. (How is this even possible?)
Today, I can't even get it to open at all.
I've tried downloading v2.2 again, but I can't get W7 to re-install it. Double click on the installer, nothing happens.
I'm somewhat hampered by being unfamiliar with Windows - I got Parallels and W7 solely to run SD.
Can anyone suggest anything please?
Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)
Posts: 593, Visits: 4.9K
I would suggest going into Control Panel > Programs and uninstalling SkyDemon.
Next, make sure you delete any remaining shortcuts from your Start Menu, Desktop and Taskbar.
Finally, download and reinstall SkyDemon again.
ffg
ffg
Thanks! I'll try that.
ffg
ffg
Hmmm...
tried that - Control Panel>Uninstall Program>Uninstall SD... seemed successful, trashed the shortcut.
Dowloaded fresh SD 2.2. Re-launched Parallels, double click on SD installer - little blue circle for a few seconds... then nothing. SD is not present in the All Programs window.
Maybe there's a problem with W7 itself or with Parallels?
Mohameds
Mohameds
Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)Too Much Forum (111 reputation)
Posts: 1, Visits: 4
apple accessories ipad 2 leather cases ipad2 cases
ffg
ffg
The problem turned out to be with the Windows 7 installation itself - don't know why but it just stopped working, though it would boot up inside Parallels.
I fixed it by re-installing Windows.
I find the whole W7/Parallels experience slow and tedious. Hoping that SD for iPad will render it redundant (even though I have roughly £150 invested in W7/Parallels!
Happy New Year all! Safe flying!
nwhite007
nwhite007
Posts: 30, Visits: 293
I use Mac OSX Lion with VMWare Fusion running a virtual Windows XP machine and Sky Demon works fine with this set up, syncs with SD Mobile device no problems.
filippo1974
filippo1974
Posts: 12, Visits: 38
ffg (01/01/2012)I find the whole W7/Parallels experience slow and tedious. Hoping that SD for iPad will render it redundant (even though I have roughly £150 invested in W7/Parallels!
Virtualization can be quite a hassle at first. First of all, make sure Your Mac has enough RAM. When You deal with virtualization, the more the RAM, the better the performances. Based on my experience, 4 GB of RAM are the minimum acceptable amount for a good experience.
Next, it is important not to assign too much RAM to the virtual machine, because that RAM is taken away from that available to Your Mac for its needs. A thumb rule would be not to exceed half of the available physical RAM.
Windows 7 requires at least 1.5 GB of RAM to give acceptable performances, 2 GB is the sweet spot for a virtual machine using it, so Your Mac needs at least 4 GB of RAM to be able to decently run a virtual machine with Win7.
I have a self-built PC, running Ubuntu Linux with 4 GB of RAM and a virtual machine with Windows XP using Virtualbox (an Open Source equivalent to Parallels). I assigned 512 MB of RAM to that virtual machine and I'm fine with SkyDemon, as well as many other applications.
Hope this helps.
Regards,
Filippo
Filippo1974
PPL(A) holder - CPL + IR + MEP in progress
Senior specialist in throwing Italian ATS units into panic every weekend.
