syncing to garmin 495 creates custom waypoints
vfr-uk
vfr-uk
Posts: 51, Visits: 81
Hi there,
Having spent a few weeks playing with the web version of the planner, I've decided that - for the time being at least - I'm going to go for the Windows version on my mac (through vmware), since it has more features like GPS sync and better printing options.
I've got a question though.  When I synced a plan that included waypoints built into my Garmin 495 (NDB's etc), Skydemon made custom waypoints for them instead, rather than use the built in database.  It works the same (apart from not having the correct icon) so no big as far as I can see initially, but I just wondered why this is?
We don't explicitly create any waypoints at all, the device does that on its own. I am aware that where possible we tell the device that a waypoint is likely to be in its own internal database, but this doesn't always work unfortunately. I think that's why you occasionally see a duplicate waypoint.
vfr-uk
vfr-uk
Thanks for the info.
vfr-uk
vfr-uk
PS, having been evaluating skydemon web, and plan (on my mac through vmware) for the past weeks, I've now purchased.
It's a great product, and I hope it continues to evolve.
vfr-uk
vfr-uk
Just to follow up on this with some more info for you (since through further testing many waypoints that are in the Garmin DB get made as custom waypoints from a Skydemon route).
The positions seem slightly out between Skydemon and Garmin (current database)
Using Compton VOR (CPT) for example:
From the Skydemon plan (custom waypoint CPT created)
N 51 29.500
W001 13.183
CPT in Garmin 495 DB:
N 51 29.503
W001 13.179
I guess this slight discrepancy is why the custom waypoints are being created?
Edited 6/6/2011 3:48:21 PM by vfr-uk
It depends on the logic the Garmin device uses, but it seems like a good guess to me. We use the position as promulgated through the official AIP.
vfr-uk
vfr-uk
Interesting....
I'm no expert on this, but it looks like your numbers are correct decimal formats of the AIP data, and the Jeppesen data is slightly different.
Do you have any contacts at Garmin/Jeppesen? I'd like to send them a query about their data.
Many thanks
We've spoken to a chap at Garmin UK technical support on the phone, I think his name was Alasdair.
vfr-uk
vfr-uk
have submitted the query to Garmin and Jeppesen. Will keep you posted if hear anything back.
pink leader
pink leader
Posts: 518, Visits: 2K
I think most of the flight planning packages do this. Howver, the key is to be able to delete them as a Group. This requires the planning software to put them in the same (but different from other dedicated Garmin points) category. Not sure if SkyDemon does this but I suspect it does  .. certainly the symbol is different.
So from time to time you can purge them without jeopardising other stuff.
D
