Visits: 3.2K
I like all of the suggestions already made, and have a couple of other suggestions to make in addition:
Would it be possible to have a "zero wind" plog - given that the forecast is almost always wrong, having to undo the wrong wind to apply the correct wind doubles the mental maths I have to do. That said, adding a "max drift" box at the top of the plog would be useful.
Second, most of my flights are "out-and-back" on the same day, usually following the same route. At the moment, I print the plog for one direction, go back to the main window, reverse the route, and print the second plog. Since I also use the "two pages" mode, this wastes two half sheets of paper. Could you add a "also print reverse route" option to the plog?
Cheers,
Mike.
