Suggestion: allow edit of aircraft callsign in flight log
vfr-uk
vfr-uk
posted 8/26/2019 7:54:47 PM
Visits: 81
As per title, I don’t have a SD profile for all club aircraft of same type, would be great to be able to simply change callsign in saved flight log.
Gerhard66
G
Gerhard66
posted 8/28/2019 6:55:51 PM
G
Visits: 330
Just a workaround:
You can easily copy the aircraft definition file multiple times on your PC and rename and edit the files with a simple text editor.
vfr-uk
vfr-uk
posted 9/1/2019 6:55:45 PM
Visits: 81
Thanks. I don’t really use SD on my computer much but might try as a workaround. That said since they’re all Warriors I’d kind of just love to be able to manually drop the callsign in after flight.
Presumably others may not have profiles for every aircraft they fly?
