VRP and Reporting points
bambuko
bambuko
Posts: 10, Visits: 27
At the moment SkyAngel Plan lumps both of these together and you can only toggle them on or off together.
As a true VFR guy I seldom (if at all) use Reporting points and would prefer an option of switching them off, leaving only VRPs (in a manner of 1:500 000 chart that shows all VRPs and only Reporting Points for for ADRs and certain Recommended Routes).
Chris
2high2fastagain
2high2fastagain
Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)Too Much Forum (6.2K reputation)
Posts: 43, Visits: 98
I think this is a good point. Most VFR pilots only use VRPs perhaps with the exception of when they are flying to placed such as Guernsey etc. Separating the VRPs from the other reporting points under the Mapping menu would be a helpful enhancement. Perhaps two option 'Show VRPs' and 'Show Reporting points' would be best. The non-visual reporting points seem to be referred to as 'reporting points' in the documents I've found so while there is scope for confusion by doing this separation, I can't see anything better.
bambuko
bambuko
Latest version addresses this issue - thank you Tim!
