SkyDemon
Skydemon Light does not create PLOG
almost
Too Much Forum
Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)Too Much Forum (92 reputation)
Posts: 1, Visits: 1
Going mad trying to get SkyDemon Light to create a plot. It simply does not do it after i click on Plog and OK in the little dialog box.
When i click ok nothing happens, i do not get the usual second browser window which can then be printed. nothing.
Also, if i click on "help" nothing happens.
I believe it must be a Safari/Silverlight issue.
But I have run a diagnostic from the silverlight site and it tells me i am using the correct version and is working.
I access SkyDemon Light from my iMac. Running 10.7.5 and Safari version is 6.1.6
Can anyone help?
I also tried with Firefox. When i try to open SkyDemon Light it tells me i need Silverlight (!) but i do have it. I tried to download Silverlight again just in case, went through everything. restarted Firefox… and again it tells me to get Silverlight!
Driving me mad.
Can anyone help?
thanks
ckob
Too Much Forum
Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)Too Much Forum (95 reputation)
Posts: 1, Visits: 1
Had the same problem - PLOG will be opened in a new tab, and even though that's not standard behaviour, either SkyDemon or Safari considers this to be a popup.  So you have to allow popup windows (Safari -> Preferences -> Security, then untick the 'Block popup windows' box.  Luckily, that becomes effective without a restart, so you can temporarily allow popups to create the PLOG and then turn the popup blocker back on again to minimise grief from other websites.
If the SkyDemon development team is checking this forum - would be great if you could have a look at the issue and see whether there is a workaround.
SkyDemon Team
SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)
Posts: 5.1K, Visits: 3.6K
It's beyond our control if your browser blocks our popup.
Existing Account
Username:
Password:
Select a Forum....
SkyDemon Forums
