SkyDemon
Lat & Long Units?
Lat & Long Units?
John Jeffrey
Too Much Forum
Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)Too Much Forum (684 reputation)
Posts: 6, Visits: 11
Lat is shown as a 6 digit string (and Long as 7).  Clearly the first two are degrees, and looking at the way they change I assume the format is (d)dd mm ss, but I can't find any confirmation of this in the documentation.  Am I right?  Pity if so, because the G1000 accepts waypoint inputs in the format dd mm.mm.
If I am right, is there a way of persuading SD to display minutes and decimals?    Not that I can't do conversions, but you get lazy as you get older  . . .
srayne
Too Much Forum
Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)Too Much Forum (24K reputation)
Posts: 388, Visits: 8.1K
John Jeffrey (8/11/2015)
...is there a way of persuading SD to display minutes and decimals?
From the 'Setup' menu choose 'Change Units' and select 'Degrees, Minutes' under position.
Edited
8/11/2015 3:17:17 PM by srayne
John Jeffrey
Too Much Forum
Excellent, thank you very much.  Except that I can't find a Setup Menu!  Is it missing from the Light version, or am I just a potential Specsavers customer?
Edited
8/11/2015 3:28:16 PM by John Jeffrey
SkyDemon Team
SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)SkyDemon Team (287K reputation)
Posts: 5.1K, Visits: 3.6K
The Light version does not have support changing of units.
srayne
Too Much Forum
You can access the 'Setup' Menu through the 'Upgrade' Menu Smile
Existing Account
Username:
Password:
Select a Forum....
SkyDemon Forums
