Visits: 49
Dear Sir, It would be great if you could evaluate to change the way, in a future version, you show the important info during the Approach and Landing procedure. During these moments you haven't the time to load the geo referenced map about the approach and the aerodrome when you have to reach the parking slot or the fuel station. These maps are also to 'heavy'. I think that this is the most important difference between SkyDemon and Jeppesen VFR App. It would be great if you could add some info directly on your (fantastic!) map (better if optionable in setting), like for example: - the type of circuit for each runway (left / right hand) - reporting point: mandatory / not mandatory - minimum/maximum altitude for reporting point - entrance and exit way after takeoff and before landing - taxiway name - Parking name and general location - fuel station location You can view directly all these infos on the map during the (automated) zoom.
What do you mind? It will be possible to have such a features in a future version?
Thanks a lot in advance
Andrea
