ASUS PHONE PAD 2
sooty757
sooty757
Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)Too Much Forum (519 reputation)
Posts: 4, Visits: 42
NOW  I've found how to use the forum any one used this.
it,s mg372 lte,
with 4.4.2 and 2x Intel atom processors ,
it freezes ,or crashes all the time especially if the map is swiped
the earlier model was a much slower device and works fine
alan I am lost?
sooty757
sooty757
Well I sent this oft to Mr Asus ,not a helpful bunch at all, They  didn't fix the screen problem either. and it came back with a new motherboard ,and  a month later it still will not run Sky Demon
am i destined to buy a watch and navigate Lancaster bomber style.
  Something about the drawing catche may be??
Edited 10/27/2014 5:28:19 PM by sooty757
Posts: 593, Visits: 4.9K
That device has an Intel CPU - almost all other Android devices have ARM CPUs.
This means that SkyDemon will be running using a thing called 'binary translation'  - it's a very unusual scenario and I'm not entirely surprised that it doesn't work.
Do all other apps work?
sooty757
sooty757
HI thanks very much for your reply, it seems some other apps don't work either ,but most do,since I posted this I have indeed discovered that it's Intel processor uses x86,   not, ARM as do most of those weirdo named prossessors,(."snapydragon", sounds like a girl I knew from Bridgend))
But should run Houdini to work thing out but I guess the conversion job it does,is just to slow, shame because lots of ASUS products use INTEL. except the Nexus, also build by them.
 I can just about manage on Air Nav pro ,but the Android version is miles(NM) behind SKY DEMON.
I did ask Sky Demon "central "but they  could not help,
Still got to speak to the normally helpful and lovely Hanna H
 thanks again
Edited 10/27/2014 7:31:56 PM by sooty757
sooty757
sooty757
unfortunately I have become a bit of a SD addict, so I guess ill have to find a solution .
Replying to an ancient post here, but the Android build now supports Intel CPUs so the information above is no longer valid.
