Weight & Balance Problems
http://forums.skydemon.aero/Topic9952.aspx
By dave_kent - 7/28/2013 3:00:04 PM
Hi, I'm trying to enter the weight and balance schedule into SD (windows) but I think I've got some problems with the units relative to each other. Hopefully the attached scans of the schedule are readable and someone can tell me what I need to put in the fields (I think it's something to do with the CoG setting!).
https://dl.dropboxusercontent.com/u/60772029/2013-07-28%2014.38.48.jpg
https://dl.dropboxusercontent.com/u/60772029/2013-07-28%2014.38.56.jpg
https://dl.dropboxusercontent.com/u/60772029/2013-07-28%2014.55.32.jpg
Thanks in advance
Dave
By filippo1974 - 10/15/2013 9:59:06 AM
I resumed this thread just to notify that I found some abnormal behaviour of SkyDemon plan (for PC) when configuring the weight & balance limits for an aeroplane.
When the regional settings of Windows are configured so that the decimal separation character is the COMMA ',' and the list separation character is SEMICOLON ';', then SkyDemon on a random basis does not read and use all the points of the w&b limits polygon I defined, and/or does not consider subsequent modifications made to the polygon definition. Unfortunately, the aforementioned regional settings are by default for an italian setup of Windows.
If I manually modify these settings to have '.' as decimal separator and ',' as list items separator, then everything works just fine.
SkyDemon Plan 2.7.2, Windows 7 Ultimate x64, all patches & updates by MS in place (including those for the .NET framework).
Best regards,
Filippo
